1990 mercruiser 4.3 no power in gear. Sluggish and rough
Hey folks. So I read a few posts about engine bogging down, however, I feel my case may be slightly different.
first time out ram awesome. I noticed a lot of water in bilge area. Turned out to be a cracked manifold. So I replaced both manifolds (other was cracked too) and risers both sides.
I also replaced spark plugs and gapped at .35.
changed fuel filter.
Changed the battery
today it started great. Go to get on plane and it’s like I’m towing a freight liner. Lots of vibration and sounds like crap. engine oil looked fine. No water leaks out of anywhere
Any likely culprits ?
also, on our first trip a dinged up there prop on the boat launch when I drove it onto the trailer. No major bends. Just small chunks missing. Could that possibly affect it this much ?
it ran better with two cracked manifolds lol.
serial #OD382045
Rick Stephens
Recheck firing order.
When you changed the filter, did you dump contents into a clear container and look at it?
A dinged up prop can certainly cause vibrations. Look at it carefully to be sure it isn't bent to a different pitch.
Thanks! I’ll start there. I’ll dump the fuel filter and check. I’ll go through the spark plugs and make sure they’re in the right order
tpenfield
Gee wiz . . . 2 cracked manifolds . . . I wonder how that happened ??? :rolleyes:
What else might have cracked :noidea:
How's the engine oil look ??? chocolate or coffee milkshake?
