1990s 25 hp evinrude wont go into gear
Ryanbarbs9314
Hi i recenetly replaced the lower unit.
The prop locks as if its in drive. The prop also locks as if it in reverse. And spins freely in netural.
When ingaging uptop i can not get the rpop to spin
Willyclay
Welcome to the forum. Model number would help. Is gearcase thru-hub exhaust or not?
Remove water intake screens.----When operating the shift lever , do you see the shift rod moving up and down ?
