1991 Johnson 200 GT Carb issues
Blacksmith84
When squeezing the bulb as it build pressure fuel pours from 1 of the carbs. Is this likely a stuck float? Should I pull the bowel and clean or take to a professional.
Faztbullet
Pull carb and check it. Either the needle is worn(do all 6 if worn ) or debris under tip..
