1991 yamaha 200TXRP not peeing
cpt.nofish
bought and replaced new water pump and impellor kit -- still not peeing. tested in a bucket of water and also with muffs-- still not peeing.
didn't replace water pump housing because it looks good.
all passages clear--still not peeing. H--E--L--PPPPPPPPPPPPPPP
Ray Neudecker
Re: 1991 yamaha 200TXRP not peeing
First be sure the pea hole is clear. Remove all dirt dobbers.
edzzed
use compressed air to blow it back into the motor while it is running. might dislodge a piece of mud.
shredder07
was it peeing before new imp.if so maybe you put the imp in wrong.my suzuki has trouble going from time to time i take a piece of 100 pound test and snake it in it usually works something outa there,possibly flakes of corrosion or rust [in my case].run it in the bucket or with the ears on to test for flow wile snaking.:cool:
