Hello all,
I am new to this forum and have I am having issues with my 1992 3.0L, EST distributor Merc. misfiring when over 2200 RPM. A little history - I was cruising across a lake at 4000 rpms and then the engine started to miss, about 10 minutes later it died and I was not able to restart. It has an EST dist. and this is the work I've done since, but to no avail. I changed the Ign. coil, spark module inside the distributor, spark plugs, cap and rotor, checked plug wires, (3000-5000 ohms depending on length), checked the pick up coil - ok, it was right in middle of specs. I can start the engine but it runs a little rough and will not rev over 2200 rpm without misfiring and popping in the carb. I pulled the fuel filter in the pump ( to eliminate the filter) and ran external gas source to eliminate the fuel tank. still the same. I didn't see any fuel in the clear rubber line from the fuel pump to the carb indicating a bad fuel pump. What am I missing - could it still be a defective fuel pump? Any help would be appreciated. Thanks
