bluebackfisher
- Mar 4, 2020
- 50
I have a 1992 force 150 hp outboard and it doesn’t seam to be charging the battery adequately. The volt meter in the Dash of the boat says when it’s running that the voltage is under 12 at times? It never seems to charge above 12 or 13 V . The charge of the batteries gets so low that it’s hard to turn the boat over at times? If anybody has an idea what could be causing this problem I sure would appreciate some insight. Someone told me that may be the rep stat. If This is the problem how do I test to see if it’s defective or not?
