1993 Bayliner Capri interior
Brucet1971
I just bought a 1993 Bayliner Capri 2050 for a super good price. Engine was new. Hull is solid. Floor redone. Need to do seats and cushions. Any recommendations on where to get new cushions for the bow seats? Or am I better off going to local upholstery shop?
Brucet1971
By who?
Pix of floor in process?
Sounds like a poster for deckover work
I did not get pics of the before. He did have receipts both for the engine install, and the rear deck that was done a little over two years ago with the fiber raft, marine grade plywood, and currently it is painted in gray awlgrip. Everything where I can see underneath through the cubbyhole in the center of the stringers all look fine and that at least what I can see there’s no soft spots but the cushions need a makeover. Also need to do the panels that run down the side. They are in pretty bad shape and want to clean that up.
todhunter
Canoeist
Unless you get lucky enough to find the same make/model/year boat being parted out with the interior in good condition, you'll likely have to visit your local upholstery shop.
