So, gummed up carb, just tried adjusting idle screw in handle and turned it all the way left and pushed choke in and its off to the races
If a outboard has been trolled for a long time sometimes an "Italian Tune - up" is in order. That means at least 10 minute run above 3000 r.p.m. Works wonders sometimes.
Or roughly 150 psi of pressurized air shot into the drain screw hole.![]()
