1993 fourwinns help!!!!
Status
Not open for further replies.
losiandy1
I have a 1993 Fourwinns 190 horizon with the ford 302 cobra efi/ OMC drive. Boat has been running GREAT. i start hearing a fluctuation in the idle jumping up and down. boat runs smooth at higher RPMS but at idle it surges up and down gradually surging higher and higher and eventually smoothing out for a moment and then surges again. i've tried the MAP sensor, IAC valve, TPS sensor, replacing the battery, cleaned the air filter, replaced the anti syphon valve not long ago, sprayed out the throttle body, fuel pump pressure is at 30 something psi. i haven't been able to find a vacum leak but i'm still looking. i'm so confused because it runs great at anything other than idle. any suggestions would be appreciated. thanks.
my next thought was possible the alternator? the electrical system isn't getting enough voltage? i looked at the gauge and its reading just above 12-13.
any input or suggestions would be appreciated
Status
