Alright guys, I really wanted to be useful in my first post and answer a question, but no no, not for me. I must ask.
I have used the search function extensively and looked for what might be a logical answer before asking. I was able to find however that it is irritating to not post make model etc...
So without any further holdup -
Mariah Talari Z - Make
5.7 Motor
280 DP outdrive to the best of my knowledge
My issue:
My trim/tilt system went on the fritz after an electrical issue the other day on the season's first run. I shorted a terminal off my battery, i guess I tightened too much or my weak started pulled to much current, all I know is that now when I try to tilt/trim it clicks like it is trying to engage however, no movement. I have removed the pump and have direct connected to a battery to tilt/trim up/down successfully. I get solenoid clicks, where the heck should I look I hope I provided enough info. I can't find any other fuse other than the one by the distributor which is a 40A and not the 55A my book said. I have a wiring diagram but it doesn't tell me where the actual location of the components are.
Thanks
Josh
5.7 Motor
My issue:
Thanks
Josh
