1993 Yamaha sterndrive engine issues
jdittl
I have two issues with engine 1- when under power if you press the trim button the engines bogs down electrically 2- when accelerating above 3200 rpm's the engine starts to backfire. the carb has been rebuilt, the distributor cap. rotor and plugs have been changed and i have check electrical connections with no change - nayone have any ideas? was wondering if it is the control module in the distributor?
Ayuh,.... Welcome Aboard,.... #1 sounds like Bad/ Corroded Grounds,.....
#2 still sounds like a lack of fuel,.... Tank, fuel pump, carb,.....
Capt Ken
Early on Yamaha had a problem with that and I believe it was due to faulty ground on alternator.
