1994 5.0 with OMC Cobra
NitroBert
I am rebuilding the outdrive on my OMC Cobra. The tapered roller bearing went bad on the pinion gear. I replaced the bearings and now ready to re-install but I can't a spec on the bearing pre-load. I have it set at about .004" right now but I need to know the spec before assembling. I marked the spanner nut before removing it to have a reference but it's too tight if I move it back to the original position. Any help is greatly appreciated. Robert
JaseBosto
Re: 1994 5.0 with OMC Cobra
Go to the adults only section at the top of this forum, I think there is a manual for you there. It should fill you in on all that info.
