Re: 1994 5.7 gi pmda initial timing problem
Thanks for responding, Yes it runs very well as long as both plugs are connected to the delco-EST breakerless, electronic, high energy ignition system. The book shows 2 connections to the back- aft side of the distributor where only 1 has wires connected to it. The port side is smaller and is connected to the coil and is not an issue. the starboard side plug (in the Volvo book) has a cap on it with no wires and it is to be removed to connect the shunt for base timing. My starboard plug has 4 wires going to it which heads forward into the loom. Removing these 4 wires appears to be killing power?? Ive tried all timing possibilities within the distributors limits. Still searching for a solution.
Just to add after reading the sticky... There are no engine numbers- long story. It appears to have spark but just wont fire? Maybe the fuel injection is disabled? A local Volvo mechanic was stumped? and said I was doing everything right? Maybe there's a different shunt for this motor? Sorry that's all I got
Im back to answer my own question just in case anyone runs into this? I found out you DO NOT use a shunt connected to the distributor, but actually connect a small code reader tool (PN-94008) to the connector in fron t of the engine. Turn on the swith while the engine is running and your in timing mode. That simple! This will work for the GM- Delphi MEFI-1 thru MEFI-4 systems only.
