1994 Force 120 Thunderbolt ignition Tachometer hook up.
kbh121956
Serial No. 0E089004, Anyone know what color (s) wire run a tachometer? I want to hook one up. Also what Tach is needed? Thanks.
Redbarron%%
You would need a tach for a 20 pole motor The gray wire from the regulator is the wire. If there is not a gray wire one of the yellow ones will do. It measures the A/C pulses from the stator.
Faria made one for the force outboards.
tg3690
FYI....Faria no longer makes 20 pole tachs...
kbh121956
Thank you. Yes I have a gray, red, and 2 yellow wires on the regulator. I'll look for a 20 pole.
tg3690
Count the poles on your stator to be sure.....Marineengine.com and Crowley both show 2 stators depending on model #.....a 12 and a 20 pole......
jerryjerry05
1655809636155.png9710A45, if it looks like this?? Then it's Mercury.
CDI puts out a replacement, it looks like the Prestolite stator with a bunch of poles, but it's still a 12 pole.
The second one is CDI 12p
