1994 force 150 hp
dloya0965
looking for some help cant get my force engine to start pulled plugs cleaned them sprayed starter fluid inside and in carbs will not start starter is working great to. what should i do
jerryjerry05
Re: 1994 force 150 hp
More info please??
What does it do and did it ever run for you?
You do anything to it?
Check the flywheel.
Check the compression/spark??
More info.J
roscoe
Do you have spark?
Have you checked the kill circuit?
