Krazykanuk
- Jun 25, 2020
- 6
So I just got a 1994 doral splash boat with a sportjet 90 motor in it. It was seized and the little history I have in it was that it used to run but sat for 5 yrs. let diesel fuel sit in cylinders and now engine is unsiezed.
I have tested Stator and trigger, some parts of both test on and others do not.
it has the red stator update with the chocolate bar box added, but the block serial number sticker is worn off. How do I find out serial of the motor to get correct stator, trigger and starter solenoid/relay?
also how can I tell if it has the CDM update or not?
thanks in advance
thanks in advance
