Just bought this boat.
Everything worked as it should, I raised and lowered the drive countless time while in the driveway.
Put it in at the ramp and as I was backing off the trailer the motor raised up as if the lock rod on a manual trim wasn't in.
Ran the boat to test and the drive won't tilt up and down.
Get boat on trailer, found fuse blew, answers why drive wouldn't go up or down.
With the boat on trailer and the motor in the down position, I can lift the motor up by hand (same thing as putting it in reverse), let go, motor drops back to original position.
If I raise with the trim motor, I can do the same thing and it will drop to it's trimmed position.
Will not go down without using the trim controls even if I push on it so it's not bleeding down.
I've checked the o-rings on the manual release they are good.
