1995 Johnson V4 Shift linkage
TrenchFisherman
I replaced my water pump and now trying to get the linkage connected properly. I slid the pin mechanism back through the linkage but is it suppose to slide through the other hole on the starboard side of the shift rod? Right now I can get it to shift but this black bracket seems to be bending away from the cable so I am not sure if that is because the pin isn't all the way in?
