1995 Mercury Force not peeing
bonzoso38
Anyone have experience with these Force engines not flowing through the tell-tale. I noticed this late last year and was out about 20 min. from the dock and had to run in because of a storm and had it at 3/4 throttle all the way in. No overheat horn and my inspection at the dock showed no evidence of overheating or a clogged pee hole. I tried cleaning out the tube and still no flow. Anyway a guy I know said that these motors sometime are like that. So I kept using it and have put on about 15 hrs. since I noticed it, and still shows no overheating or evidence from it. Just want to find out if this is truely a problem or not with these motors.
Jiggz
As mentioned try inspecting the t-stat housing first and then if possible use LP air to blow it back. Another thing is to test the t-stat to make sure it is opening and not blocked.
