On my 1999, there are two red buttons for the breakers. Before you invest the money in new parts such as a starter, you need to consider what else needs to be done to that boat to get it running. For example, you say its the original impeller (from 1995). IMO, that's you over heating issue. If the impeller is that old the fins have turned from soft rubber to brittle rubber and likely broke off, thereby not able to push any water flow. The hours on the engine don't matter when the impeller is over 20 years old. Secondly, you need to check the condition of the exhaust manifolds. Are there any signs of rust from where the risers meet the manifolds?
There are also several other annual maintenance items associated with the lower unit - ujoints, drive shaft, drive oil, bellows, gimbal, etc. If these haven't been maintained, and I'm betting they haven't since the impeller is original, then you'll have to deal with those items too in addition to what is preventing the engine from starting.
You can try draining the engine oil and looking for signs of water intrusion to see if the block cracked or to see if a gasket failed due to overheating. If the oil looks good, you might be ok - or the engine wasn't run long enough after the damage for water to mix with the oil. Either way, lots of things to check and consider before dumping a marine starter (do not buy an automotive starter) into it.
Manuals are available online for free - start here in the sticky section -
http://forums.iboats.com/forum/engi...es-outdrives/479879-adults-only-no-exceptions
and here...
http://forums.iboats.com/forum/engi...uiser-i-o-inboard-engines-outdrives/366271-vp
and here.....
http://boatinfo.no/lib/library.html#
