1995 Yamaha heat alarm problem
rwilmac
The overheat alarm on my 1995 Yamaha 115 is going off. I replaced the water pump and both heat sensors . It is peeing strong and doesn't feel excessively hot but the alarm goes off after running on plane a couple minutes. I ran it in the boat slip for 5 min. and the alarm never sounded, it peed good and water was not hot. I need some suggestions, please. Thanks.
ianyoung77
Re: 1995 Yamaha heat alarm problem
I would check out the thermostat. If it's not full of gunk check the operating temperature
rwilmac
Thanks, I'll try that. A friend also suggested backing down kinda hard in reverse to dislodge any grass that might be hung up.
Could that be it ?
Thanks for your help?
Ray Neudecker
Also check the poppit valve at the rear of the motor. Be careful not to shove the grommet into the block while checking or cleaning.
pine island fred
Check my post YAMAHA OVERHEAT FIX post on 11 NOV. Just might be the problem. FRED
rodbolt
first ya gotta determine is it an actual overheat or is it an oil alarm.
if its a precision blend model and the oil filter at the remote tank is clogged it will run a few minutes then trigger the alarm as the engine can use oil faster than it can be transfered if the filter is clogged.
use a temp gun to find the actual temp of the motor.
with a strong stream at low speed and no low speed overheats I would not suspect the poppit valve at all but it does need routine maint .
worst case is pull the heads and covers and clean the salt scale off of everything.
