1996 Force 75 Internal Fuel Lines
foster0004
Hello, I am trying to replace internal fuel lines In my 1996 Force 75 ELPT. Is there any documentation on the tubing sizes? The first line I want to replace is the line from the bottom of carb bowl to the primer solenoid... Can this be replaced with tubing or is it a specific molded fuel line? Wondering about the O.D./I.D. specs... It looks like the carb barb is smaller than the primer end?
Also, what Ethanol resistant brand and grade of tubing do you recommend for fuel lines under the cowl? Thanks!
jerryjerry05
Just replaced the recirc hoses on a 98/120
I believe they are the same on all the Mercury
model motors.
1/8" hose.
The barbs are the same.
Just ask for Ethanol resistant hoses.
