millertime77
- Sep 20, 2013
- 4
Took lower end off in neutral (apparently a no no, reading posts) replaced water pump impeller and now can't get the lower end up tight. Turned the flywheel and got it seated about an inch away. Now no matter what i do (shifting forward, neutral, reverse) i can't get that last inch. Greased all the splines (not the top). Wiggled and pushed and swore
still nothing. What is hanging me up? Do i need to drop it again and start over fresh with a different procedure? Thanks
