1996 Mercury Force 15hp Lower Unit Removal Help
Zwc32
I need to remove lower unit to replace impeller. After removing the 4 bolts, it will drop down a couple inches but the shift linkage is holding it. I can not find where to disconnect it. I can not find instructions or video online so any help would be greatly appreciated.
jerryjerry05
There should be a screw and nut holding the 2 pieces of the shift shaft together.
You might have to shift into gear to drop the lower unit further down.
