I took the boat out to let a buyer test drive. Before he drove it, everything was checked and normal. After the test drive was over, i decided to take it on a final spin around the lake when it suddenly died in the middle. I checked the battery and kill switch, both were good and it was not overheating. I was turning at the time it died. I was told it may be hydra locked. When i got home i did the following:
Checked the battery voltage-normal
Removed and tested the starter-works fine
Re-installed the starter, removed my plugs and tried to turn it over-will not turn over, moves about 1/4 inch when turning the key
Looked at the dipstick and realized there is probably triple the amount of water vs oil and what looks like vanilla pudding under the valve covers.
Block is not cracked, as far as i can tell anyway.
How could water have gotten in the engine and what may be the issue? Bearings? Pistons? your help will be greatly appreciated!
