1997 force 120 buzzing sound after about 5min
jla011868
Hey guys any ideas? I have a 97 force 120 and after about 5 min a slight buzzer sound is coming from the control areas. I have a good strong flow from the pis..r hole and the water is cool. any ideas faulty sensor, buzzer, waterpump,? doesnt seem to be o/heating and the fuel pump is not a vro i have to mix the gas. any ideas getting ready for a tourney thanks
jerryjerry05
That's usually an overheat buzzer.
The pee tube is just an indicator like the buzzer.
It tells you it's pumping and doesn't mean it's staying cool??
I bought a temp gun and added it to my box O tools.
The cooling passages could be blocked and the area on the head where the temp gauge is gets too hot?
Pull the thermostat and check the condition??
I had a 40 Yam buzzing.
The pee tube was peein real good.
The thermo and cooling passages was so clogged with crud it's a wonder it didn't blow.
The pics were from a running/pumping motor.
