1997 Mercury 115HP flywheel stuck
kkgoral
The flywheel is stuck on my 115 hp mercury outboard I pulled the plugs still no luck.<br />Then I pulled the lower unit still no luck.<br />what is the next step to solving this problem.<br /><br />thank you <br />kkgoral
MurdockJr
Re: 1997 Mercury 115HP flywheel stuck
The plugs and lower unit have nothing to do with the flywheel. I suggest a wheel puller and a shop manual before you do anything else. :rolleyes:
clanton
Remove the head and look for damaged piston.
