1997 mercury 75hp outboard.
Rick M.
Any Ideas?? My engine starts and runs fine but only out of gear. With shift disengaged[cold start position] Iget plenty of rpm.Once in gear I can get no mre than Idle speed regardless of throttle position. All linkage is correct new plugs filters all that jazz. and it seems to have come on suddenly. just had carbs serviced 10 months ago. maybe 20hrs use so far.Any thing you can think of will help. As im stuck in port and the tarpon fishing is hot!! :confused:
JB
Re: 1997 mercury 75hp outboard.
Hi, Rick.<br /><br />Welcome to the board.<br /><br />You could do a search on power loss, but about a thousand Q&As from this board are on www.outboardrepairs.com cataloged.<br /><br />Try there and if that doesn't help come back and tell us what you did and what happened.<br /><br />Good luck. :)
Rick M.
10-4 Great place to start thanks Ill post results :p :p
