Hi all,<br />I was able to get the upper & lower shift rods to connect, unfortunately i can only get neutral at the propshaft or the prop shaft is locked -won't turn either way.. The shift rod on the lower unit will only turn about 1/4 of a turn in either direction. How do I line up both upper & lower shift rods to be in the same gear? This engine has a cam-shift unit not an EZ Shift unit. According to the manual the engine was placed in forward gear when the lower unit was removed. Help-my back is killing me. Sullymate
