1998 dt150 wont idle
cb guy
Hey folks, great site, I have a 1998 dt150 that wont idle, the idle screw is pegged already so there is something else causing this, so far this is what has been done, new plugs, new fuel filter, compression is 100 in all 6 cylinders<br />{by the the way this is a efi no carbs} last fall I put on a new head and manifold gasket because <br />I was getting water in #3 cylinder and it ran fine after that, when I got it out of storage it had a idle problem, I live in a area where there are not many folks that can or will work on this engine, will it run if the high pressure fuel pump is bad? I have a suzuki service manual, but not all the test equipment, thanks for any help..<br /> Steve
