BoatingCop
- Aug 28, 2007
- 408
Ever since I bought my boat I've been trying to track down a stumbling/poor acceleration issue. It's also had an idle issue. Compression is good 130 psi all around, Both carbs were removed and cleaned, and spark checked out well. One thing that I haven't thought about is the exhaust housing/cover. I bought this boat damaged from a hurricane. The swells sent the boat into the top of the boat house that it was in. When this happened, it cracked the top of the exhaust housing. The P.O. had JB welded it back together. I notice that while running a little water leaks out of the top of the JB Weld, and has progressively got worse. I recently was running the engine on the hose and the flusher slipped off for a second. As the water pressure in the engine got lower, the better the engine ran. Could this crack in the top of the housing be causing my poor running condition? Does this mean that the block is toast do to the housing being part of the block? As far as I can tell, it's not oil water coming out of the crack. I'm beginning to think that I may just need a new power head. Any thoughts on this? Thanks!
