how can i check to see if the motor is charging
B boone68 Cadet Joined Jul 29, 2007 Messages 19 Jun 21, 2011 #1 how can i check to see if the motor is charging
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,842 Jun 21, 2011 #2 Re: 1998 force 120 hp not charging Put the leads of your volt meter on the battery terminals when engine is off, should read 12.4 or so when fully charged. With the engine running, it should read 13.8--14.6, depending on the rpm's.
