tallcontrol
- Mar 27, 2009
- 4
I have a 1998 Force 120hp and am the original owner. This year the motor is very hard to start. First start is usually not the problem but after running it and shutting it down and then trying restart is. It will start after a long period of cranking or you start with throttle up higher than idle or if you choke it it will fire initially and then eventually start after cranking for a while. As of yesterday it will sometimes die when putting it into gear. There are no issues once running idling or cruising the problem occurs when restarting. Any thoughts on where I should start?
Thanks
Thanks
