1998 force 40hp engie help
rageman
Recently when trying to get my boat on plane when I first start out and throttle up the motor starts pulling then the rpm,s start goin up but the boat doesnt go any faster ( feels like its slipping).When i back off the throttle then power up again ( sometimes twice) it will run fine. It only seems to do it when its cold then the rest of the day I wont have any problems.I shouldnt say cold because I have a 200yd no wake zone that I kinda putter thru before I can power up.I dont hear any grinding and it doesn,t slip out of gear because when I back off the throttle it will still pull. Anyone ever had this problem?...Thanks Scott
jerryjerry05
Re: 1998 force 40hp engie help
Sounds like a spun hub on the prop???
Take a marker and draw a line on the hub and the prop housing.
Next time you go boating after your done and it slipped.Check the line and see if it's moved.
rageman
I,ll check it . I just put a new prop on and it did the same thing with the old one.
jerryjerry05
If it does it with 2 props???
Maybe I misunderstood???
When it's running right,what RPM's is it running at WOT??
What size prop?
