1998 Johnson Ficht 175 water in fuel alarm
whalerbob
Late last season my the alarm on my outboard starting going off and the engine light would come on. Evinrude diagnostics says it is water in the fuel. I have drained the fuel twice and I have never seen any evidence of water, the water separator is new, I replaced the fuel line and bulb from the water separator to to the engine, I have removed the lower engine cowling and did a visual inspection of all the fuel lines. It's important to note the problem is intermittent. This is probably not related but I will throw it out there anyway, I had the boat running for about 10 minutes without the fuel cap on, I put the fuel cap on and the alarm went off almost immediately. I took the cap off and restarted her and the alarm went off again. Anyone have any ideas where to check next?
Faztbullet
Code 37 was a common problem false code on 1998-99 models..only fix is to have EMM updated. Don't have any idea why cap does this other than vent clogged.
whalerbob
When I took my water filter off earlier today it was only half full, shouldn't this thing be full after running? Do you have a easy way of checking to see if the vent is clogged? A clogged vent would possibly explain the alarm after putting on the fuel cap.
whalerbob
So I checked the sensor wire for continuity and it checked just fine. I ran the engine and the alarm and light came on, I disconnected the wire to the sensor and started the engine and the alarm came on. Is it safe to assume it's the ECU?
whalerbob
I got the ECU back yesterday from the computer guy and the problem appears to be eliminated, no alarm and no engine light. Thanks
