treeboy0515
- Sep 23, 2003
- 1
I have a problem with my heat alarm coming on after running and then switching to idle.It has a steady stream of water all the time at pee hole.I removed the cover from engine and noticed a yellow wire coming from what i think is the temp.sensor.the insulation is off the wire.could this be from a bad sensor or could it be grounding out and causing the alarm to go off?i dont think its really hot but dont wanna chance it(u never know)thanks in advance
