kperusich7
- Aug 3, 2012
- 4
I just purchased a 99 bayliner with a Force 120 on her and these are the current issues i am having and wondering if any of you have some ideas.
1. First thing it does is when i throttle forward using the neutral switch, it works at first then about half throttle it jumps into gear. Bringing it back to the dealership to fix this, they will probably give me the run-around though.
2. Next the top carb, seems to leak fuel out when idleing, adjusted the fuel/air mixture screw but it doesn't seem to do anything, thinking maybe the float is bad allowing the fuel through.
3. When going WOT it will only reach about 4600 RPM, when i bring WOT with the engine off the carbs do not go completely flat. I have read some things about a lync and sync but cannot find info how how to actually do it, do you think this would help.
Also do they make a service manual for this motor, i have the clymer one already, but it just doesnt have alot of information in it.
Kevin
Kevin
