1999 Four Winns Horizon 170 with Penta 3.0 What Prop??
evansmp
New to boating and I hit a rock and took a chip out of my prop but I cant figure out what to by to replace it and I can't find a model number on the old prop.
should be either outside the hub or inside the hub. your local prop shop can help
QBhoy
Usually on the props most often found on that set up, the details will be written on the hub just behind where the nut on the shaft is. Will say something like 14.5x19P or similar.
