1999 Mercury EFI 200HP
JoeSalv
Experiencing problems with the bulb staying primed. The engine appears not to be getting sufficient fuel. I have changed the bulb and I have replaced the fuel filter. I am thinking it may be a problem with the anti siphion valve or the fuel pump. Does anyone have any suggestions? If so please email JoeSal@comcast.net <br /><br />Thanks<br /><br />joe
JB
Re: 1999 Mercury EFI 200HP
First thing, Joe:<br /><br />Post it in the right forum.<br /><br />Moving to Merc Troubles.<br /><br />Good luck. :)
greasemonkeyozi
Ok, a fuel problem is at hand. Go ahead and buy you a fuel pump diaphram rebuild kit, $5.00 at any dealership. <br /> Wouldnt hurt to rebuild, and tune your carborators, but first.<br /> Go to NAPA and purchase something called SEA Foam Deep Creep, $7.00 a can. Take your spark plugs out and spray a good bit in each cylinders. Let set overnight and start motor next morning. Then spray some in your carborators and watch all kinds of nast stuff blow out your exaust. Use 1/2 can per 3 tanx of fuel for good preventive maint.
