1999 OptiMax with low water pressure !!!! Help
letsinger
I have a pair of '99 optimax saltwaters. One motor has low water pressure that I cannot correct. Both a mechancial gauge connected to the compressor water jacket and the DDT confirm the low pressure. I have replaced the water pump, checked the top screen (top of block), checked the check valve, thermostats and still no improvement. last week I switched the lower units which confirmed the issue is not the water pump. This engine has had this problem off and on for about 3 years and appears to actually completely clog after going though dirty water (weed lines). There does not appear any real deposit build up in the block (thermostats, check valve, top of block screen.) I am at the point of pulling the block to see if there is a problem in the exhaust plate, but I was hoping someone might have a suggestion.<br /><br />thanks,<br />Joe :confused:
letsinger
Re: 1999 OptiMax with low water pressure !!!! Help
I meant popet valve verses check valve.
vinney
Check the bypass valve If that checks out ok. And you use a factory water pump/parts. The early 99 opti's had a copper water tube. Some of the water tubes got holes in them. The updated tube is stainless steel.
Does this model have a water cooled ECM. If so some models had problems with the tube that cools that ECM becoming clogged. Just a thought
