Hello all. Just found this site and already need some advice! Last spring i bought my first boat. It is a 1983 Hydra-Sport X-260, with a 1983 johnson 90hp seahorse engine. It has power tilt and trim, the prop is 12 3/4 by 21, with a hydrofoil installed. The higest rpm it ran was around 4500 at 42 mph measured by that thing on back with a clear hose attached to speddo. Just reading thru some of the forums it seems that in order for my motor to run at peak performance i may need to install a new prop. Not neccesarally looking for more speed, just optimum thru all rpm range.Thanks for all replys!
