Re: 1st time boat owner
You can start by reading the "sticky" at the very top of this forum. After you've done that, you need to make sure the engine is making full power, making sure the throttle is opening the carbs all the way, making sure the link & sync procedure is correct on the motor, making sure the hull is clean, making sure you are not lugging around a boat load of water in the form of water soaked foam. Lastly, telling us what prop diameter and pitch is on the motor -- which is why I asked you to read the sticky note. You said you understand the "load" issue. But just because there are six seats does not mean you have enough engine to make the boat perform. You can buy a car with a four cylinder engine and you can by the same car with several sizes of V6's and perhaps even a V8. Even though all those cars have room for four, five or six people doesn't mean the 4 cylinder will perform the same as the V6 or V8 when you have any number of folks inside. Likewise, the number of people listed on the capacity plate is based on people weight of 125 - 150 pounds. Six 150 pounders is 900 pounds. Six 200 pounders is 1200 pounds. Just because you have seats for six does not mean you can safely carry six people. It's all about loading.
