2.3 cobra parts
rabbyg
hi every1, does anyone know where i can buy 2.3 cobra engine parts in uk im in need of a timing belt tensioner and distributor cap and a few odds and ends, any help would be greatly appreciated...
ifallsguy
Re: 2.3 cobra parts
You should look at Ford cars/trucks for tensioner and timing belt. I found a timing belt kit with belt and tensioner for a 1987 Ford Ranger 2.3L is the same as the "marine" kit, but at about 1/3 less the price. You do need to verify the part. If you can interchange this part number (NAPA NBH 2520140) it might help. As for distributor cap, make sure you get the proper marine cap. It has a gasket to help keep moisture out. That one I cannot help you with.
zbnutcase
Re: 2.3 cobra parts
If you have the stock dist, it's a Mallory YL series and caps are readily available via mail order. summitracing.com 'nutcase
