2.3L OMC spark plug wires from distributor pictures
mtb1981
Hi everyone. Long time lurker, first time answer poster. I've been trying to sort out this problem with my 2.3L OMC Cobra with the malllory distributor. Long story short, I pulled all the spark plug wires out by the cable and not the boot, and severed one cable because I'm a moron. I Bought new cables but forgot what position on the distributor was which, and I couln't decode the manual's diagram, so I was stuck. I finally got it by removing the #1 spark plug and sticking a long (2-foot) drill bit into the hole, then hand cranking the engine to see where the distributor's rotor was pointing when the piston was as top-dead-center. I had such a hard time with this, I thought I would post a couple of pics of the spark plug wires in the right order.
FYI, the plug wires are sierra marine's p/n 18-8807-1
The oil filter is a Fram PH-8A
The fuel/water separator is a sierra marine 18-7846 / OMC 502905
