2.5/3.0 Mercruiser - bolting old style riser onto new style manifold
HRK
Does anyone know if there's an adapter out there that would let me mount the old-style 2.5/3.0 riser on a new style 2.5/3.0 manifold? Water channels and mounting holes are different, but due to my pre-alpha transom assembly I need to use the original style exhaust. Just hoping someone makes an adapter plate so I don't have to swap the entire intake/exhaust manifold to make it work.
Nope,..... Either swap the manifold, or swap the down-pipe,.....
achris
More fish than mountain goat
New style down pipe 'should' bolt straight onto the old style transom housing.... But, you'll need to pull the engine to do it.
HRK
That's what I thought too - but the pre-alpha transom plate blocks the down pipe from fitting. The pre-alpha has the engine mount holes further apart than the later Alpha 1 style, so the support gussets on the transom plate itself are in a different spot - the down pipe hits the transom plate and won't sit flush against the transom housing :(
So, I either need to cut the transom plate (not happening), or use the pre-alpha downpipe. But that downpipe doesn't line up with the new-style riser on the motor. Which means I guess I need to use the pre-alpha style riser as well. But THAT doesn't bolt onto the new style exhaust manifold...so I suppose that's being swapped out too.
I considered buying an alpha-1 transom plate instead, to replace my pre-alpha. That would make it so much easier - exhaust would bolt on, and I wouldn't have to swap out for a smaller flywheel on my new motor either. But I don't know if my existing cable steering would bolt onto the Alpha 1 transom plate? Looks like it mounts differently than mine.
achris
The post 1983 inner transom plate (narrow engine mounts) will bolt up to a later MC1 gimbal housing (with the round trim senders)... but you would have to change the flywheel housing for the engine to mount. A whole new can of worms. This is why people are so reluctant to work on 'frankenmotors'.
