Hi I have a 2.6 xp (basically a hopped up 235 crossflow) 1984 After idling in gear for a while the overheat horn sounds if I jump on it and get on plane after a minute or so It goes off. I have 2 new thermos installed (143 deg) and a new impeller. At idle a have little water pressure > 3psi at 3000 rpm I have 12-15 psi and at wot I have 20 psi. I was gonna pull the thermos and check them but they are new. Also after a while the motor will not rev up in gear it boggs out. I don't think it is a carb issue cause it comes and goes. I am thinking maybe after idling for a period in gear the plugs are fouling . This happen today and after letting it sit for a half hour I got it to go by feathering throttle .It will start and rev fine in nuetral. Any ideas I am using L77jc4 plugs. Can fouled plugs cause this ?
I Need old Crossflow 235 gurus. Thanks Jim
I was running bosh plugs in this last year Im gonna dig them up and put them back in
