Now I am having problems with the carb. Its a 1999 Mercruiser 5.0 305. It runs for 15-45 seconds than dies. I restart it with the same thing. I tried adjusting the fuel/air ratio and it ran real slow for a while. Then it died again. I could mess with the screw at the front and it would help a little sometimes but not much. It still continued to die. Just before it dies it will raise the rpm's then die. A couple times I would be able to save it by throwing it into neutral. When I would put it in neutral it would go to the idle speed rpm's. Then I put it in gear and it runs for a second real sluggish, revs up and dies. Needless to say I finally gave up and had to be towed in.
