2 Cycle, a bit of water in the fuel, what's the best way to deal?
Columbia
I've been advised to not use an 'water remover' mixed in to run the small amount of water through because it is a two stroke (1994 6 hp Suzuki, 100/1). There is enough water, I suspect from in tank condensation, to stop the motor but only for a minute. Shake the tank up, runs fine 'til the water resettles. Advice on this greatly appreciated!!
Fouled Plug
Ensign
Re: 2 Cycle, a bit of water in the fuel, what's the best way to deal?
It's fairly cheap to run an inline water seperating fuel filter. Might seem 'overkill' for a small engine, but clean fuel is always a plus. I'd be tempted to toss the fuel you have and start over if the amount of water is significant.
Columbia
Probably the best advice. In the old days I poured it out and burned it or ran it through my carburetor car. Now I have fuel injection...no place in town to 'recycle'. What are folks doing with a quart of of mixed fuel with a bit of water in it?
roscoe
I always find a way to "use it up", but most are not safe.<br /><br />Lawn mowers, snowblowers, weed trimmers, etc.<br /><br />If you change your own oil, you could pour it in the waste oil bucket and take it to the recyclers.<br />It all mixes up and is re-refined.<br /><br />I know a guy that saves his for winter, then adds 6 ounces to every tank of deisel in his tractor and pickup.
Calabrio
JUST A WORD ABOUT MIXING YOUR OLD GAS WITH MOTOR OIL...<br /><br />Don't do it. Do not dispose of gasoline by mixing it in with your oil. First of all, it creates a dangerous condition for those handling the oil, something that is not nearly as volatile as gasoline.<br /><br />And,in high school I remember working at an autostore. When ever someone came in with gas in the oil, we'd turn them away. <br /><br />Just call the local landfill, they'll tell you where you can dump the gas. Here, in Florida, they have a bunch of hazordous waste spots, and you can recycle as many 5 gal tanks of gas as you'd like, at no charge.
