Re: 2 cycle motor oil poured in each cylinfer at spark plug hole how long to burn oil
If it's a two-cycle motor, just run it with your normal mix. If it's a four banger, run it with straight fuel. Might want to check your plugs after the smoke clears (pun intended) ...
