How do you guys deal with mixing you gas and oil when filing up at a marina. I got a 20 gal tank and figure if I add oil them fill the tank. By the time I drive to the ramp it will be mixed. But what about filling up at a marina, how do you mix it then? Second. Is there any issue with using my pontoon as a ground when wiring up lights, or do I need I need to run the negative up to the bus bar in the console?
